2001 Oldsmobile Intrigue Oil usage 1 1/2 qts each oil chang
2001 OLDSMOBILE INTRIGUE
140,000 MILES • 6 CYL • FWD • AUTOMATIC
FGTJBB
Moldsmobile intrigue uses oil, approx 1-1 1/2 qts between oil changes. It doesnt leak (not a drop) and doesnt smoke at all. It has always used some oil between changes. Even when brand new it used almost 1/2 qt. each time. There are no knocks or noises in the engine compartment and it truely runs great. The only issue is that I have to watch the oil all the time. ANY IDEAS WHAT TO CHECK?
Mar 9, 2009 at 11:53 AM
BLACKOP555
  • 10,386 POSTS
if it always leaked 1/2 a quart, but now it only takes 1 quart more after 140,000. its a bit high but not that bad.
try adding some oil stop leak and see if that fixes it!
Mar 9, 2009 at 1:51 PM
