2001 Oldsmobile Intrigue no spark after changing camshaft a
2001 OLDSMOBILE INTRIGUE
50,000 MILES • 6 CYL • FWD • AUTOMATIC
ROCO2000
Car wouldn't crank. Found main negative ground wire bolt out 1". Tightened and car cracks, but no spark. After getting codes 335, 340, 385 (in that order) on 2001 Intrigue 3.5L, changed crank sensor, camshaft sensor, and checked for compression to assure timing chains were good.
Now get code 340, sometimes with couple of attempts 340, 335, 385 in that order and no spark.
Looked at fuses and relays and think they are all good.
Any reprogramming after replacement? Any other components? Has two coils above spark plugs, assuming they are good.
What to do next?
Jan 26, 2010 at 4:22 AM
SCOTTY DEE
  • 592 POSTS
If the car wont crank, there is a problem in the starter circuit.
Jan 28, 2010 at 3:21 PM
