2001 Oldsmobile Intrigue metallic noise
2001 OLDSMOBILE INTRIGUE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
SPOONMAN80
i bought this car used from a friend about 2 years ago and it has been making a strange metal on metal rubbing noise from the front suspension under acceleration from a dead stop, i took it to a dealership mechanic and they said i had 1 control arm bushing that was completly worn out, would that be the reason for the noise, or would it be from the front struts or steering rack
Jul 15, 2009 at 3:52 PM
  • 31,937 POSTS
Hi there,
I would get the bush replaced and have the rest check, they will have to do an alignment as well, start here.
mark (mhpautos)
Jul 15, 2009 at 4:29 PM
SPOONMAN80
just replaced the control arm bushings on both sides today. along with both sway bar links. the car handles ALOT better now and the brake wobble i had seems to have gone away, feels alot more solid up front. but, i still hear that noise under acceleration. im wondering if its those rusty front struts even tho they dont show any other signs of being bad.
Jul 28, 2009 at 2:54 PM
  • 31,937 POSTS
Hi there, try giving the struts a liberal dose of spray on lube (WD40 or similar) see if that stops the noise.
mark (mhpautos)
Jul 28, 2009 at 3:31 PM
