2001 Oldsmobile Intrigue High Idle
120,000 MILES • 6 CYL • FWD • AUTOMATIC
SBODRIE
I am having problems with my car idleing higher than normal. I believe that it should be around 700 to 900 RPM but sometimes it will be around 1500-2000. If I turn the car on and off a few times the idle will go back down but once I drive it will go back up. I am assuming that the problem is with a sensor or an electrical component but do not know where to start. Where do you think that I should look first?
Oct 15, 2008 at 3:41 AM
DOCFIXIT
  • 18,828 POSTS
Any codes check engine light? Maybe problem with Idle Air Controler Motor located on throttle body ECM sets idle speed with IAC
Oct 15, 2008 at 6:14 AM
SBODRIE
could it be the Idle Air Controler Valve, that is all i can find to replace and i was thinking that that was the problem. also could it be the mass air sensor?
Oct 15, 2008 at 6:23 AM
