2000 Oldsmobile Intrigue No air blows out of vents when in
2000 OLDSMOBILE INTRIGUE
66,000 MILES • 6 CYL • FWD • AUTOMATIC
DIPLOMAT1
When i turn on my ac or heat no air comes out on either. Why is that? Please help thanks
Aug 2, 2010 at 7:50 AM
ERNEST CLARK
  • 1,730 POSTS
First check the fuses. If they're good, then you'll need to access the blower motor and apply voltage directly to the motor.
If it works, then the issue is in your control panel or wiring. If it doesn't work, replace it.
If you need instruction on doing this, let me know.
Sep 18, 2010 at 3:24 AM
