2000 Oldsmobile Intrigue help confused?
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DESTINEE68
my car starts when it wants but sometimes it trys to turn over but seems like it is not getting no fire. we have replaced the catylytic convertor the air filter the oil and filter and fuel filter what else could it be?
maybe the spark plugs or ignition switch or oxygen sensor? please help i have tryed everything and noone can seem to answer the qwuestions i need answered
Nov 9, 2009 at 5:10 PM
JDL
  • 16,098 POSTS
Welcome to the forum, when the problem occurs, if it cranks good but won't start, have a helper crank it while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. also, check for troublecodes, around here some of the national brand autostores will check codes for free.
Nov 10, 2009 at 12:33 AM
