2000 Oldsmobile Intrigue FRONT END
2000 OLDSMOBILE INTRIGUE
184,230 MILES • 6 CYL • FWD • AUTOMATIC
ROBERT WEBBER
THE FRONT END HUMMS.SHAKES,GRINDS,THE MORE WEIGHT THE HARDER THE SHAKING,ENGINE CUTS OUT THEN THE CHECK ENGINE LIGHT BLINKS.I PUT A NEW THERMISTAT IN AND IT OVERHEATED TOOK IT OUT ITS FINE,IT DOES NOT USE ANTIFREEZE AND NO WATER IS IN THE OIL,REPLACED BRAKES,WHEEL BEARING,THE REPAIR SHOP DID NOT PACK IT WITH GREASE COULD THAT BE THE PROBLEM?COULD IT BE THE CB JOINT?
Jun 22, 2010 at 5:59 AM
  • 110,244 POSTS
Have you checked the brakes? Does the noise change when you make turns? Also, are you sure you didn't place the thermostat in upside down?
Nov 4, 2010 at 6:32 AM
