1999 Oldsmobile Intrigue WONT START. I GET 4 TAP
BLKTREKNSTL
  • 1999 OLDSMOBILE INTRIGUE
  • 6 CYL
  • FWD
  • 185,000 MILES
WHEN I GO TO CRANK THE ENGINE, I ONLY GET. TAP OR CLICK NOISE. 1234. USAULLY RIGHT BEHIND EACH OTHER
Thursday, June 11th, 2009 AT 8:45 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
Friday, June 12th, 2009 AT 7:39 AM
