1999 Oldsmobile Intrigue noises coming from the front end
1999 OLDSMOBILE INTRIGUE
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
RBMABRY
trying to find out what is causing the grinding noise that seems to be coming from the front end
Sep 2, 2010 at 6:18 AM
ERNEST CLARK
  • 1,730 POSTS
If it's a grinding noise the sounds like metal on metal, then your brakes are worn and are grinding against the rotors.
If it sounds more like a whine from a jet engine that increases with speed, then it's your wheel bearing.
Sep 8, 2010 at 10:38 PM
