1999 Oldsmobile Intrigue Fuel FILTER/PUMP
124,000 MILES • 6 CYL • FWD • AUTOMATIC
TJH1981
Trying to figure out which I need to replace. Cold starts in cool weather aren't an issue. It cranks up first turn - - but in warmer weather or with any warm start it will take 5 seconds of cranking before starting up, having to keep the pedal pressed.
Oct 3, 2010 at 5:00 AM
JDL
  • 16,098 POSTS
I'd use a gage and check fuel pressure. If you have an injector leak, it might cause a warm restart issue?
Oct 3, 2010 at 5:05 AM
