1998 Oldsmobile Intrigue Fuel Pressure
KARENCLARK2008
Engine Mechanical problem
1998 Oldsmobile Intrigue 4 cyl Two Wheel Drive Automatic
What should fuel pressure be for a 98 Oldsmoible Intrigue?
Dec 20, 2009 at 6:48 AM
ERNEST CLARK
  • 1,730 POSTS
First, your engine should be a V6, not a 4-cylinder.
Your fuel pressure should be: 48-55 PSI (Pounds per Square Inch)
Vent the fuel tank vapors by loosening the fuel cap. Position the ignition switch and the A/C system in the off position. Install a fuel pressure gauge to the vehicles fuel pressure valve. Confirm that no leaks are present, and with the key on, engine off verify the PSI reading on the gauge.
If I've helped you, pleas vote for me, as I depend on this to pay my bills. Thanx, Ernest.
Jan 24, 2010 at 12:46 AM
