1998 Oldsmobile Intrigue Enhanced Traction Control System
245,000 MILES • 6 CYL • FWD • AUTOMATIC
ABOORMAN
HI,
I am having a problem, when i start the car there are no indicator lights on. when i put the car in reverse to exit the driveway the LOW TRACTIOn light comes on. it goes out when i put the car in drive. when i stop at a stop light and apply the brake, the TRACTION OFF light & SERVICE ENGINE SOON light comes on. the car hesitates before giong and i have to apply alot of pressure to the gas peddle to get the car moving. i have checked the brakes and calibers, replaced the wires and coils and added fuel injector cleaner. There are no codes showing when i run the computer on the scanner. Any ideas?
Aug 11, 2009 at 3:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Heres the deal a scanner that reads engine codes can't read ABS/ETC codes need a Tech2 ie. dealer. Some independent shops may have newer enhanced ABS scanners. That's why your not seeing codes .
Hope this helps
Thanks for donate
Aug 12, 2009 at 2:27 AM
