1998 Oldsmobile Intrigue drivers side hvac actuator has lim
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUG WESSEL
The drivers side vents with the ac on delivers low flow and a higher temp then the passenger side. The drivers side actuator has a limited range compaired to the passengers side. I exchanged the two actuators with each other. The problem stayed on the drivers side. I replaced the control box with one from a salvage yard. Nothing changed. How can I determine if I got hold of another bad control box or if there is another problem?
Oct 15, 2008 at 8:48 AM
2CARPRO JACK
  • 11,533 POSTS
Have you had the car scnned for "B" codes? The climate control system will store a code if it sees a problem, the codes will start with B
Oct 16, 2008 at 12:59 AM
