1998 Oldsmobile Intrigue 6 posinition mis fire
1998 OLDSMOBILE INTRIGUE
130,000 MILES • 6 CYL • FWD • AUTOMATIC
PZODMAN
My check eng light is on and when I had it checked the code came up as a 6position Mis fire.
should I have new spark plugs put in along with spark plug wires?
Feb 21, 2010 at 5:55 PM
Are you referring to #6 cylinder misfiring? If so,check spark plug/wire,fuel injector and compression on #6 cylinder.
Feb 21, 2010 at 11:07 PM
