1998 Oldsmobile Intrigue
135,000 MILES • V8 • FWD • AUTOMATIC
BUBSINTRIGUE
Instrument panel quit working. Well everything but the speedometer quit. I replaced it with another and it did exactly the same thing. I'm at a lose as to what to check. Any help would be appreciated.
Aug 22, 2010 at 6:58 AM
LEGITIMATE007
  • 5,121 POSTS
this is usually an indication of a problem with the body control module, what most likely is happening is there is some corrosion on one of the connections therefore there is not a good connection for power or ground, it will need to be inspected.
Aug 27, 2010 at 7:34 AM
