1998 Oldsmobile Delta 88 dark instrument cluster
STRYCHARSKE
Electrical problem
1998 Oldsmobile Delta 88 110,00 miles
The other night my wife discovered that the instrument cluster of her car was dark. The car started and ran okay, but no instrument lights. Also, the chime sounded when the driver's door was open even though the key had been removed from the ignition and headlights were not on. I checked appropriate fuses and they were okay. What next?
Jan 25, 2010 at 2:04 AM
  • 110,248 POSTS
I would recommend having the headlight switch checked. It determines if you get power to the inst panel.
Apr 13, 2010 at 12:03 AM
