1996 Oldsmobile Delta 88 transmission problem.
1996 OLDSMOBILE DELTA 88
100,000 MILES • 6 CYL • FWD • AUTOMATIC
PAMPERIN_D
My trans. car will not move right away, as the temp. gets colder outside it takes longer for it to take off, summertime it fine but as winter approaches it has to warm up first could this be the transmission module, causing this.
Oct 23, 2010 at 2:11 AM
MERLIN2021
  • 17,250 POSTS
Probably not, it's more likley to need a band adjustment and or oil and screen change, Go to the tranny shop and ask them to test drive it and explain the symtoms. Fix could be simple, or extreme!
Oct 23, 2010 at 1:47 PM
