1995 Oldsmobile Delta 88 Fuel system
DLECH8
Engine Mechanical problem
1995 Oldsmobile Delta 88 6 cyl Automatic
I can get fuel in to the fuel rail but the injectors don't fire. What is the controller for the injectors
Oct 29, 2008 at 1:14 PM
  • 75,988 POSTS
Is the fuel pressure within specs? If so-check for power at the injector connector pink wire-do you have it?
Oct 29, 2008 at 3:25 PM
