Where is the Fuel Sensor located?
SXYSD
Sensor Installation. Where is the fuel sensor located?
Sep 17, 2009 at 2:33 AM
SQM
  • 6,383 POSTS
The fuel level sensor is part of the fuel sending unit. It is located in the fuel tank. It is the same unit that houses the fuel pump.
In order to replace the sensor, the fuel tank needs to be removed. That will provide access to the fuel sending unit.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Nov 28, 2021 at 5:00 PM
