1995 Oldsmobile Delta 88 Fuel Sensor
1995 OLDSMOBILE DELTA 88
SXYSD
Engine Performance problem
1995 Oldsmobile Delta 88 V8 Front Wheel Drive Automatic
Would a fuel sensor prevent a 1995 Ods Delta 88 from running. It seems to regulate the proper fuel level for the fuel. gauge. I have a new fuel pump installed. That insures fuel gets to engine. I think the fuel injectors are messing up, The engine starts, runs a bit then dies as if no fuel. Pump is pushing fuel cause it can be heard. New fuel filter in place also.
Sep 17, 2009 at 10:38 PM
