1995 Oldsmobile Delta 88 Car died.
180,000 MILES • 6 CYL • FWD • AUTOMATIC
CYLEHEIRSCH
  • 5 POSTS
A few days ago I was driving and I pressed the electric seat adjuster and my car died right there. My car was empty on gas so I filled it up and It wont start now. I press my electric locks and my dome lights and side lights go on and off with every click. I checked all the fuses and none of them are blown. I checked the engine fuel thing and no gas is getting to it. I changed the fuel filter and fuel pump but still no go. Any ideas?
Oct 1, 2010 at 8:30 AM
  • 75,988 POSTS
Do you hear the fuel pump come on for a few secs if so check the fuel pressure if not check the fuel pump fuse and fuel pmup relay
Oct 1, 2010 at 11:12 AM
CYLEHEIRSCH
  • 5 POSTS
[quote:9b068c297a="rasmataz"]Do you hear the fuel pump come on for a few secs if so check the fuel pressure if not check the fuel pump fuse and fuel pmup relay[/quote:9b068c297a]
I dont hear it. When I jumpstarted the car it acted like it was coming on but then died. And It has no fuel pressure at all.
I checked the fuse and its good.
Oct 1, 2010 at 11:16 AM
  • 75,988 POSTS
No fuel pressure -check what's happening with the fuel pump though its new-could be a pressure leak due to injectors and fuel pressure regulator leaking
Oct 1, 2010 at 11:19 AM
CYLEHEIRSCH
  • 5 POSTS
[quote:cadf39e9e8="rasmataz"]No fuel pressure -check what's happening with the fuel pump though its new-could be a pressure leak due to injectors and fuel pressure regulator leaking[/quote:cadf39e9e8]
Any reason to the locks and lights interacting?
Oct 1, 2010 at 11:25 AM
CYLEHEIRSCH
  • 5 POSTS
Still not working.
Oct 3, 2010 at 7:06 AM
CYLEHEIRSCH
  • 5 POSTS
I love that I get answers one day then im stuck when I really need help.
Oct 7, 2010 at 3:21 AM
