i justy changed my brakes, but abs light is still on. now my left caliber brake is sticking what should i do?
Dec 18, 2009 at 2:26 AM
HMAC300
✓Experienced Mechanic
take it to a pro in your area. He'll need to find out wat theABS problem is as it could be a sensor or wire, anything on the system. If you have a sticking caliper they will need to be both replaced with a new or rebuilt unit. YOu just don't replace one you have to do both. Unless your brake hose is bad as that could cause it as well.
