i justy changed my brakes, but abs light is still on. now my left caliber brake is sticking what should i do?
Dec 18, 2009 at 10:26 AM
HMAC300
✓ASE Certified Mechanic
take it to a pro in your area. He'll need to find out wat theABS problem is as it could be a sensor or wire, anything on the system. If you have a sticking caliper they will need to be both replaced with a new or rebuilt unit. YOu just don't replace one you have to do both. Unless your brake hose is bad as that could cause it as well.
Jan 18, 2010 at 1:40 PM
