1994 Oldsmobile Delta 88
JMILLER3
dash lights dont work everything else seems to be ok and working
Feb 17, 2010 at 6:07 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Do the lites for the radio and hvac assembly work? There may be a dimmer control, headlamp switch, rotate one way or the other. Somebody may have turned it all the way down? You can also check fuse 4A-- 10 amp fuse.
Feb 17, 2010 at 6:20 AM
