1994 Oldsmobile Delta 88
1994 OLDSMOBILE DELTA 88
252,200 MILES • 6 CYL • FWD • AUTOMATIC
MARIONIX
My car is cuttin' off like its out of gas but it cranks back up after 10 - 30 mins. I change the fuel pump, fuel filter, and tune it up too. When its crunk it runs good. But when it cuts off it sometime don't want to start after keep turning the ignition it sometimes a crank like it never happen.
Jan 4, 2010 at 4:06 AM
HMAC300
  • 48,601 POSTS
this could be your crank sensor but you should have a an engine code. If you dont' a pro should be able to diagnose it with other equiptment to actually test the sensor. You may not have needed all the other stuff you put on the car.
Jan 18, 2010 at 5:33 AM
