1992 Oldsmobile Delta 88 Unsolvable problem?
121,000 MILES • 6 CYL • FWD • AUTOMATIC
DEVIN23
Hi and thanx for taking the time to read this, the problem is its runs horribly rough on idle and backfires with acceleration also noticable power loss now list of new parts include, IAC, MAF, O2 Sensor, coil pack, ignition module, 2 sets of plugs and wires, ecm, front exaust manifold, vaccum test, fuel pressure test and everything is ok. No check engine light, node light tested, tested intake multiple times with multiples substances was ok still can't find the the problem. Had it on the snap on scanner everything read ok accept the rich/lean was always cean and in closed loop rev it up and open loop would kick in...... this car is great cruising down the highway, all the valves are good..... i dunno i'm stuck on this one hoping someone may have a good suggestion. Oh and its definately not the cam or crank sensor lol new
Oct 29, 2008 at 12:46 PM
  • 31,937 POSTS
Hi there,
i would have the ignition checked on an oscilloscope, as this will give you all the information that you will need to track down this problem, coupled with an exhaust emission readout you should be able to track down which cylinder or cylinders are at fault, and if all well your problem will be in the ignition or a valve timing issue, start here.
mark (mhpautos)
Oct 29, 2008 at 1:31 PM
