1992 Oldsmobile Delta 88
DREW17600
Engine Mechanical problem
1992 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic
I changed the spark plugs and the next morning it tried to start but didnt. I waited a little later and tried to start it again and the car wouldnt say nothing the dash lights work, radio, lights. But the car will not make a sound.
Nov 23, 2009 at 4:30 AM
  • 110,246 POSTS
Have you checked the starter? If not, have a helper turn the key to the start position while you check for power to the smaller wire on the starter. You should get 12+ volts. If you do, the starter is most likely bad. Remove it and have it bench tested at a parts store to confirm.
Let me know what you find.
PS: I am assuming the battery is good in the car.
Apr 13, 2010 at 2:43 PM
