1991 Oldsmobile Delta 88 Help
182,000 MILES • 6 CYL • 2WD • AUTOMATIC
REMO0969
My ac comes on but the fan is not blowing on any speed. I need help on fixing this from step one to completion
Dec 14, 2009 at 5:07 AM
HMAC300
  • 48,601 POSTS
first check the fuses for the a/c then see if you ar gettingpower to the resistor. That will probably be your problem. either the switch or blower resistor.
Jan 18, 2010 at 5:49 AM
