1991 Oldsmobile Delta 88 Engine has no spark.
175,380 MILES • 6 CYL • FWD • AUTOMATIC
CHRISSYLVESTER
Last week my car died on the highway...Backfired and lost power and then died...the next day at the towing place, the guy was able to start it to move it and it ran rough he told me....belt was broken, repaired that. I took a computer and coil pack/ICM from a donor car roughly a 1990 I believe...and put those in....also replaced the camshaft sensor and the crank shaft sensor (New)...they were also replaced along with the harmonic balancer about 4 months ago..again new.......The fuel pump is less than 6 months old and I have plenty of fuel to the rail, just no spark...what could it be?
Jun 14, 2009 at 2:55 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jun 14, 2009 at 11:12 PM
