1990 Oldsmobile Delta 88 Help please!!!!! thank you
1990 OLDSMOBILE DELTA 88
149,000 MILES • 6 CYL • FWD • AUTOMATIC
ITRUSTME
ok this should be pretty easy for yall on my wire harness that runs to my coil pack module it has a connector on the end i need to know what the little square connectors inside the pigtail on the end of the wire harness are call one of my are bent and wont slip onto the coil pack module i need a new one but dont know what they are called please help me i need to get this done quick its the only ride i have thank you
Jan 21, 2010 at 3:12 AM
JDL
  • 16,098 POSTS
Hi, I looked at the autozone online partsbook, they showed several connectors, they may have to order it. The new connector has pigtail wires, you splice the wires together. I'm sure any national brand autostore can order it for you. As far as fixing the old connector, I'd have to look at it. The one I looked at was a six wire connector, I didn't know which one?
https://images.2carpros.com/forum/automotive_pictures/170934_ignition_module_connector_1.jpg
Jan 21, 2010 at 7:01 AM
