1990 Oldsmobile Delta 88 ask a question
1990 OLDSMOBILE DELTA 88
DEEDEE35
  • 11 POSTS
Engine Performance problem
1990 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic
how do you know the air flow mass sensor is bad
Jul 20, 2010 at 4:29 PM
  • 31,937 POSTS
Hi there,
Normally they will set a fault code in the ecu, but if not and you suspect it is a problem they can be tested electronically.
Mark (mhpautos)
Jul 20, 2010 at 6:18 PM
