I have a 1990 Olds Delta 88 Royale, 318. Close to 200,000 miles. It will die when slowing down and turning. Always restarts. Seems to only die when driven at least 30 minutes. I have had it to two different mechanics. Both say the cam sensor is bad. One says this is not the problem. The other says it is.
I hate to spend the money (this is an expensive repair) if this is not the problem. Sometimes it will shutter.
Apr 13, 2009 at 3:29 AM
