1988 Oldsmobile Delta 88 Won't start or turn over
36,000 MILES • 6 CYL • FWD • AUTOMATIC
FINISHING_BOYS
  • 11 POSTS
Battery is only 3 months old. Car does not turn over. Tried hooking up jumper cables, still nothing. Only lights that come on when ignition is turned on, are both turn signal indicators and high beam. But otherwise, no radio, interior lights or anything. What should I try?
Jan 21, 2009 at 5:31 PM
  • 75,988 POSTS
Is it cranking over and refusing to start or won't crank at all/nothing?
Jan 21, 2009 at 10:00 PM
FINISHING_BOYS
  • 11 POSTS
It won't crank at all. Battery is reading 12.8 Volts. But it doesn't crank or do anything. Should I be checking for an ignition fuse or what?
Jan 22, 2009 at 2:29 PM
  • 75,988 POSTS
Pull the starter and get its current draw tested if okay-check and test the transaxle position switch and ignition switch
https://images.2carpros.com/forum/automotive_pictures/12900_start_3.jpg
Jan 22, 2009 at 2:35 PM
