1988 Oldsmobile Delta 88 battery
1988 OLDSMOBILE DELTA 88
FAYE45
battery won't charges there nothing wrong with the alternator or the battery is there a fuse i should check
Oct 11, 2010 at 3:18 AM
WRENCHTECH
  • 20,761 POSTS
Check for power at the main terminal of the alternator with the key off. If no power found, check the fusible links at the starter.
Oct 11, 2010 at 3:23 AM
