1987 Oldsmobile Delta 88 run like out of gas
1987 OLDSMOBILE DELTA 88
TOMTOMHERE2005
Engine Performance problem
1987 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic
I have a 1987 Oldsmobile Delta 88 that acts like it is not getting enough gas or too much gas.
I ve replaced the fuel filter. NO HELP !
I ve replaced the EGR valve. NO HELP !
I ve replaced the air throtle control valve. NO HELP !
Can you please help.
Jun 8, 2010 at 2:51 PM
Check the fuel pressure to rule the fuel filter and fuel pump and also test the throttle position and manifold absolute pressure sensor-
Jun 8, 2010 at 3:23 PM
