1987 Oldsmobile Delta 88 No charge light on the dash
1987 OLDSMOBILE DELTA 88
95,000 MILES • 6 CYL • FWD • AUTOMATIC
CC4669
Can not locate the alternator fuse, nothing in fuse panel is marked alternator. need help locating fuse or fues for this circuit. Car runs fine until battery dies.
Alternator is less than 3 months old.
May 8, 2009 at 7:26 AM
RACEFAN966
  • 5,029 POSTS
The two fuses for the charging system are fuse 9 and 16 in the fuse box. However as a mechanic I never assume because it is new that it is alway's good. I would take the car to your local parts store and have a charging system test done.
May 9, 2009 at 1:20 AM
CC4669
I resolved the problem, before I got your reply
Thanks for getting back to me.
May 9, 2009 at 6:23 PM
RACEFAN966
  • 5,029 POSTS
Well good so what did you find? Thanks and if there is anything more you need just ask.
May 11, 2009 at 12:14 PM
