1986 Oldsmobile Delta 88 leaking steering fluid
NICKSOLDS
Steering problem
1986 Oldsmobile Delta 88 6 cyl Automatic
im leaking fluid from where the power steering hooks up to the belts. how do i repair a leak there? it doesnt look like there is a bolt or anythng in the center of the wheel holding the belt. should there be something there?! any advice is apriciated. thanks
Mar 17, 2010 at 12:42 PM
LEGITIMATE007
  • 5,121 POSTS
no that pulley is "pressed" on, you may just have a leak where the hose goes onto the pump. look realy good, it may just need tightening, if not, you need to replace the pump
Mar 20, 2010 at 3:12 PM
