1985 Oldsmobile Delta 88 dim alernator light
1985 OLDSMOBILE DELTA 88
60,000 MILES • V8 • 2WD • AUTOMATIC
KE4QDC
I got this car from my mother and it had a dim alternator light at idle. I replaced the alternator with a rebuilt one and problem solved. Now about 6 months later and about 1000 miles the light burns dim at idle and sometimes will go out at highway speed but not always. I tested the output with the battery disconnected and engine running and got 15.3 volts. How can I test the amps output to see if it is outputting enough current or would that be necessary? Can it put out enough volts and not enough current and cause this problem?
Oct 11, 2009 at 11:53 AM
  • 110,244 POSTS
If you are getting over 15 volts, it is charging. My concern is it may be charging a bit too much. Have the alternator tested under a load. Most parts stores will do it for free.
Let me know what you find.
May 20, 2010 at 2:35 AM
