1984 Oldsmobile Delta 88 water pump
1984 OLDSMOBILE DELTA 88
LYDEE2
Engine Mechanical problem
how will i know if my water pump need replacing
Feb 3, 2010 at 2:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
failing / weak water pump will leak coolant or cause unusual noise or both. Also may experience trouble with the heat being cooler than normal and possible engine temp. overheating.
Feb 3, 2010 at 8:29 AM
