1984 Oldsmobile Delta 88 Not backing up
105,000 MILES • V8 • 2WD • AUTOMATIC
THOF
Vehicle doesn't move, when switched into reverse. When I floor the pedal, the vehicle creeps backwards slowly. Runs fine in forward gears. Had changed trans fluid and filter 5000 mi ago. Fluid level checks out ok. Any chance to fix without a trans rebuild?
Jan 13, 2010 at 3:42 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the doanation .. much appreciated A transmission rebuild should cure the fault .. sounds like the reverse clutches are burned out or bound up and need replacing !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_961.png
Jan 13, 2010 at 11:09 AM
