1984 Oldsmobile Delta 88 Noise on cold start
1984 OLDSMOBILE DELTA 88
37,000 MILES • V8 • 2WD • AUTOMATIC
GFREN
Get clicking noise only on cold start. Goes away in about 45 seconds or when driven 3-4 blocks. Seems to be coming from front exhause pipes (cat converter?) Does not return until next cold start. Car starts/runs great. Used fuel system cleaner, sea foam in oil and carb. Question: Does the cat converter have a valve? Doesn't seem to be from the engine
Jun 8, 2010 at 4:17 PM
Could be the exhaust heat control valve that's if it has one where the exhaust manifold meets the exhaust pipe.
Jun 8, 2010 at 10:57 PM
