1984 Oldsmobile Delta 88 Noise coming from front passenger
1984 OLDSMOBILE DELTA 88
184,000 MILES • V8 • 2WD • AUTOMATIC
WALLEN74
Although the noise is coming from the front passenger side strut assembly, the struts aren't the problem. What started as a soft hum turned into a loud grinding sound. The car is not in motion. When i start the car it goes away. If i pull on the wire harness on the strut assembly leading to the far left side of the fire wall it goes away. So i just unplugged it. can somebody help me. the noise is getting really embarrassing.
Jun 28, 2010 at 8:26 PM
WALLEN74
[quote:9a6144ac50="wallen74"]Noises problem
1984 Oldsmobile Delta 88 V8 Two Wheel Drive Automatic 184000 miles
Although the noise is coming from the front passenger side strut assembly, the struts aren't the problem. What started as a soft hum turned into a loud grinding sound. The car is not in motion. When i start the car it goes away. If i pull on the wire harness on the strut assembly leading to the far left side of the fire wall it goes away. So i just unplugged it. can somebody help me. the noise is getting really embarrassing.[/quote:9a6144ac50]
Never mind. i found out it was my power antenna.
Jul 2, 2010 at 5:59 PM
