1984 Oldsmobile Delta 88
JORDANHARRIS
Transmission problem
1984 Oldsmobile Delta 88 V8 Two Wheel Drive Automatic
i have a 1984 delta 88 i put a 350 olds rocket engine in it and it runs great it has a 200R4 transmisson i dont have the tv cable on yet but it jerks hard when i put it into any gear and then cuts off. but if i hold down the brake and give it gas while in gear it will run. is this because the tv cable is not hooked up or is it the idle of the car or timing . i will put out im only 17 and i love cars[img:162d1c0b9d]http://www.2carpros.com/forum/automotive_pictures/442032_Picture_372_1.jpg[/img:162d1c0b9d]
Nov 30, 2009 at 10:57 AM
  • 110,246 POSTS
Is the trans fluid full and clean?
Apr 13, 2010 at 12:09 AM
