1979 Oldsmobile Delta 88
151,000 MILES • V8 • 2WD • AUTOMATIC
SHARON MARIE
My car is leaking water and I have checked all hoses- could it be the water pump going bad and could someone please tell me where it is exactly located, I have an idea but not sure.
Apr 7, 2010 at 12:20 AM
  • 110,248 POSTS
Under the water pump is a weep hole where coolant can leak if the seal or bearing goes bad in the pump. Check that. As far as location, it is on the front of the engine. The fan is attached to it.
Let me know what you find.
Apr 12, 2010 at 2:32 PM
