Oldsmobile Cutlass
DANA28
Air Conditioning problem
Oldsmobile Cutlass V8 Front Wheel Drive Automatic 150000 miles
Ok here's my question. My air conditioner only works if i have a window cracked or mu sunroof open a little. What do I need to do to fix it?
Sep 2, 2010 at 5:19 AM
HMAC300
  • 48,601 POSTS
check to see if your fresh air door is working on your heater unit. Or if you have a cabin filter see if it is plugged. It (cabin filter) will be on the passenger side under the vent in front of the windshield. the vent should be able to lift up if you have one or not. if it doesn't lift then you don't have one.
Sep 4, 2010 at 12:48 PM
