2001 Oldsmobile Cutlass one ignition coil won't fire
162,885 MILES • 6 CYL • 2WD • AUTOMATIC
RALPHIE
  • 6 POSTS
Dear Sirs, My son has a 2001 cutlass, 3.1, v6 and is skipping and we noticed cylinder 1 and 4 are not firing. (no spark) We got another coil and still no spark. About a year ago it would not run at all and we had to replace the ignition coil module. Has the new module gone bad or does the 7x or 24x crank sensor have anything to do with this problem? I've checked all the fuses and relays and I'm stumped.
Thank you......Ralphie
May 7, 2009 at 12:44 AM
RALPHIE
  • 6 POSTS
I took the ignition module off and took it to Auto Zone where I bought it and it was bad. Fortunately it had a lifetime warranty that I wasn't aware of so all is well . Thanks all....Ralphie
May 9, 2009 at 7:50 AM
