2000 Oldsmobile Cutlass Cutlass Fuel Pump switch
2000 OLDSMOBILE CUTLASS
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
BUDHA3
Where is the fuel pump relay switch located on a 2000 Cutlass. The engine turns but will not start. I need to know where the reset button is located so I start my car
Jan 23, 2008 at 8:46 AM
Oldsmobile don't have a reset button-why don't you check for power at the fuel pump connector this is where you start.
BTW have you checked for spark-No spark is No start too. So check it out and comeback with your findings.
Jan 23, 2008 at 8:52 AM
