1999 Oldsmobile Cutlass No power to fuel pump
1999 OLDSMOBILE CUTLASS
89,000 MILES • 6 CYL • FWD • AUTOMATIC
RBAGLEY
I am having an issue with the fuel pump on my 99 Olds Cutlass. I replaced the pump and fuel pump relay and still no power. I then pulled the new pump and "bench tested" in a bucket of gas to verify it wasn't the pump. It seems to be working fine. Gas gauge is getting power, but no power is getting to the pump at any time. Any ideas where to check next? Thanks.
Jan 11, 2010 at 8:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check ground wire to the pump, it should be located below left front seat. Also, did you check the fuse?
Jan 11, 2010 at 8:57 PM
Did you check the fuel pump and injector fuse 15amp if okay and relay is good-and ground side of the relay is good-the problem is coming from the computer fuel pump control circuit
Jan 11, 2010 at 9:00 PM
