1999 Oldsmobile Cutlass Engine light
1999 OLDSMOBILE CUTLASS
RCE1980
Engine Cooling problem
1999 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
Engine lights on code reads p0401 insuficent flow. The car overheated two day before. Are the two related? Or just by chance
Oct 20, 2010 at 7:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
this code indicates a faulty EGR flow, most likely due to a dirty EGR valve. this would not cause engine overheating nor would overheating cause the EGR valve to fail.
Oct 20, 2010 at 2:17 PM
RCE1980
thanx it helps to know where to start. I did not want to fix five things, and only need to fix one
Oct 21, 2010 at 7:34 AM
