1999 Oldsmobile Cutlass Check engine light is constantly on
1999 OLDSMOBILE CUTLASS
129,000 MILES • 6 CYL • FWD • AUTOMATIC
WINSTON1949
Although i reset the computer the "check" engine light comes on after driving for several miles. I have a diagnostic done but unable to identify the problem. Can you help me to identify and correct this problem?
Dec 6, 2008 at 2:41 AM
JASONRAY
  • 213 POSTS
What was the code? If the light is on, there's a code stored. I'll HAVE to know what the code is in order to help you. I'll be glad to if you'll repost with the code. It could be a number of things. Is the car running bad. If not, it may be an emmission related code. The government makes the car makers put all that on there to protect the environment. If it's running bad, it could be something else. I'll be waiting...
Dec 6, 2008 at 2:54 AM
DEBORAHK940
look under the car at the back bumper under the trunk near the gas tank. there is a wire there with a plug in the middle of it.it is easy to see. make sure it is plugged together. same problem on my 97 cutlass. that fixed it.
Jan 3, 2009 at 11:21 AM
